Date/Time: Mon, 10 Feb 2025 01:34:43 +0000
Missing Data Intradia E-mini S&P500
View Count: 689
[2020-08-18 06:26:27]
User962067 - Posts: 11
Good Morning Sierra Chart,
I already tried all the available solutions, I deleted and downloaded the data without success, I give 1 year or 2 years to load and I only load the data correctly until the contract 06-20, from there behind the data there are missing information errors and loading only until the start of the contract 09-19, so I put that load 1, 2 years or more always load at the same point, you can notice obviously the data errors in the volume indicator.
Attached Message Log
(Removed)
Date Time Of Last Edit: 2020-08-18 12:44:17
image2020-08-17_21-40-31.png / V - Attached On 2020-08-18 06:25:22 UTC - Size: 52.35 KB - 232 views
image2020-08-17_21-41-02.png / V - Attached On 2020-08-18 06:25:37 UTC - Size: 56.56 KB - 228 views
[2020-08-18 12:44:22]
Refer to:
Continuous Futures Contract Charts
[2020-08-18 13:16:05]
The data does not load correctly before the contract 06-2020, already apply all available solutions. thanks
[2020-08-18 13:44:18]
What solutions did you use? Did you use the Continuous Futures Contract option?
[2020-08-18 15:03:49]
Thank you very much for your help, the problem has been fixed, but compared to the free CQG data in NinjaTrader the sails and ticks are very different under the same conditions, why is this? As you can see in the two charts attached both are 10946 ticks, but the two charts differ quite a lot
image2020-08-18_16-54-26.png / V - Attached On 2020-08-18 15:01:32 UTC - Size: 34.66 KB - 192 views
image2020-08-18_16-55-11.png / V - Attached On 2020-08-18 15:01:47 UTC - Size: 48.3 KB - 216 views
[2020-08-18 18:45:45]
Refer to help topic 47:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
Date Time Of Last Edit: 2020-08-18 18:46:42
