Date/Time: Mon, 10 Feb 2025 02:02:52 +0000
Instances
View Count: 555
[2020-08-17 20:12:48]
User736044 - Posts: 51
I paid for the CME data to be able to use SIerra in 2 computers 2 instances each.
If I only use 1 comp how many separate installations can i use?
Thank You
[2020-08-17 22:13:25]
Refer to the information here:
Denali Exchange Data Feed: Connections
[2020-08-18 11:48:24]
Thank You, if i paid for another set of exchange fees can I use more than 2 installations on the same computer or it only applies to the use on a different computer.
[2020-08-18 20:27:52]
If you want to use more than two installations on the same computer, then use this method here for additional installations:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
