Date/Time: Sun, 24 Nov 2024 17:06:47 +0000
Volume by price and Numbers Bar question
View Count: 1490
[2020-08-17 19:53:22]
User931593 - Posts: 28
Hi
i'm using volume by price study(1x) and numbers bars study (2xs). Is there a way to get the volume by price and numbers bar to have a little more separation from the last bar as seen in the snapshot.
On another note, is there a way to separately show Volume Profile split bid ask and then allow to show Text Based on Dominant Diagonal Ask Vol Bid Vol percentage so that the colors don't disappear into the profile.
imageVbP and Num Bars.png / V - Attached On 2020-08-17 19:46:13 UTC - Size: 80.76 KB - 723 views
[2020-08-18 13:45:35]
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-08-19 19:37:25]
1. There really is no way to get additional separation between the VbP and the Numbers Bars given the way you are displaying them. The only things you can do is to expand the time scale to make the space bigger in general, and then to lower the value for the Maximum Volume Bar Width Percentage. Refer to the following:
Volume By Price Study: Maximum Volume Bar Width Percentage
But we really recommend using a Numbers Bars second column that is set to display a Volume Profile. This will work much better and give you the same information. Refer to Step #s 12 and 13 within this section:
Numbers Bars: Step-By-Step Instructions
2. Yes, you can have those two things selected. But what you may be more interested in is the following setting to allow you to use a different set of colors for the text:
Numbers Bars: Use Separate Colors for Text Coloring Method
[2020-08-19 21:49:28]
Awesome John, Thank you. I don't know why I didn't think to use columns 1 and 2. Your the best
[2020-08-20 12:23:11]
Also refer to:
Working With Charts: Right Side Fill Space
[2024-05-11 16:31:29]
User92573 - Posts: 530
Can you provide the settings used for the Volume by Price Study that presents the Bid Vol Ask Volume Histogram as shown. Cannot seem to replicate.
Many thanks
[2024-05-11 19:28:38]
Which VbP are you referring to. There is no VbP shown in the image originally provided. The information on the right side in that image is from the DOM Graph.
We are not sure what exactly you are looking for, but refer to the following example which may be what you are wanting:
Volume By Price Study: 1 Day Total Volume with Bid Ask Delta on Right
