Date/Time: Mon, 10 Feb 2025 01:39:53 +0000
Background Color on Text
View Count: 1276
[2020-08-17 17:33:54]
Sudhirc - Posts: 54
How can i have background color on text to be transparent?
Attached chart where you can see numbers on top and bottom of the bars using Study Subgraph Above/Below Bar from Numbers Bars Calculated Values in Region 2.
http://www.sierrachart.com/image.php?Image=159768561594.png
[2020-08-18 12:30:25]
Ackin - Posts: 1865
File attached
imagetransparent.png / V - Attached On 2020-08-18 12:30:02 UTC - Size: 75.27 KB - 322 views
[2020-08-18 12:44:35]
Sudhirc - Posts: 54
@Ackin, Thank you very much, there is so much that you can do with platform. Learning every day.
[2020-08-19 19:24:22]
Here is the relevant Draw Style:
Chart Studies: Transparent Custom Value At Y (ACSIL: DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y)
