Date/Time: Mon, 16 Sep 2024 19:12:50 +0000
$TRIN chart
View Count: 1978
[2014-02-03 05:16:55] |
bwalks123 - Posts: 122 |
Is there a way to inverse the data so when the TRIN is increasing on the chart it is representing strength in the market instead of weakness? And vice versa
[2014-02-03 09:40:05] |
tobi - Posts: 351 |
Have a look at the study: Multiply Bars By -1 If you want it to be in Chart Region 1, check Display As Main Price Graph. |
[2014-02-03 13:16:35] |
Excellent that worked perfectly, much easier to read now. Thank you
