Date/Time: Thu, 02 Jul 2026 12:11:31 +0000
How To Color Volume Bars Based on Delta?
View Count: 3053
[2020-08-15 14:06:57]
User336770 - Posts: 30
I did not find a native study in sierra capable of doing this, so I thought of using the "color based on above/below study".I referenced the "bid/ask difference bars" study in the settings, applied to region 3 (where the volume bars are), but nothing happens (image attached)
imageUntitled.png / V - Attached On 2020-08-15 14:06:27 UTC - Size: 110.91 KB - 718 views
[2020-08-15 14:35:42]
User907968 - Posts: 873
One way is to use the Color Bar Based on Alert Condition study, chartbook attached to demonstrate.
attachmentColor Volume Chart User336770.Cht - Attached On 2020-08-15 14:35:32 UTC - Size: 3.88 KB - 762 views
[2020-08-15 15:05:04]
Thanks again for the study collection template.
Dear Lord, what a clunky workaround for something extremely simple... Why make it so complex? A simple option in study settings for coloring of volume would do the trick without all this juggling... There is a study called "Colored-Volume Based On Volume" that I thought it was what I Wanted, but it just color the bars if the volume is higher or lower than previous. They could have added the option of coloring based on dominant bid/ask, simple.
