Date/Time: Tue, 22 Sep 2026 11:27:12 +0000
IB Version
View Count: 1364
| [2014-02-03 01:40:52] |
| Roger Grace - Posts: 14 |
I use IB for my data feed. Recently when I log on to SC I get message that IB version 9392 or higher must be used; this is confusing, as current latest version is 943.1e on Jan 27 2014 - completely different ?? Please advise. SC appears to get time stamping from the computer clock; is it possible to use clock/time from the IB data feed instead; this is always more accurate for market opening trades etc. Please advise. Thank you |
| [2014-02-03 04:49:35] |
9392 is equivalent to 939.2, so the version of TWS you have is newer. No it is not possible to use the clock/time from Interactive Brokers. There are issues with this. And that time TWS does provide is actually the local computer time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
