Date/Time: Sat, 03 Oct 2026 16:55:16 +0000
is there a way to mark the same time across charts/symbols?
View Count: 873
[2020-08-14 20:46:26]
User845052 - Posts: 75
basically, what I would want is the ability to draw a vertical line and have it copy to a different chart and symbol. but, because chart drawings can't be copied in this specific case, idk what other option there is?
[2020-08-14 20:49:22]
before I get the suggestion to use Time Line, i know i can do that, but i ideally would like something that can be set with a click and drag
[2020-08-14 22:57:29]
answering my own question: global cursor
[2020-08-17 10:44:35]
Yes that is correct. Additionally:
You can draw a vertical line and have it copied to a different chart that has a different symbol. Just use the copy drawings capability and make sure that the option for Show Chart Drawings for Different Symbols is enabled. Refer to the information starting here:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
Date Time Of Last Edit: 2020-08-17 10:44:46
