Date/Time: Sun, 09 Feb 2025 23:41:38 +0000
Chart Drawing Menu - additional option
View Count: 561
[2020-08-14 07:24:33] |
nicktrader - Posts: 734 |
Is it possible to add the option "Snap to open/ close" (see pic) Many thanks |
[2020-08-14 08:32:47] |
User90125 - Posts: 715 |
+1 |
[2020-08-18 12:31:50] |
We will look into this.
