Date/Time: Sun, 09 Feb 2025 06:11:47 +0000
The application catches an unrecoverable exception and for safety reason will beterminated
View Count: 575
[2020-08-14 06:06:17] |
User574654 - Posts: 2 |
Hello. There was a problem trying to connect to the program. More information in the screenshots. Help me figure it out, please. Thank. |
![]() ![]() Private File |
[2020-08-14 06:07:33] |
So does this occur when you are starting Sierra Chart? We will remove this exception handling because for some unknown reason it is causing an issue in your case.
[2020-08-14 06:42:21] |
Could you please update to the latest pre-release which is now 2151. Instructions: Software Download: Fast Update This should resolve the issue. This version does not have the enhanced exception handling. We do not know why it is causing a problem though in your case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-14 06:42:40
[2020-08-14 08:38:28] |
Installed the program version 2151. The problem is fixed. Everything worked Thank. |
