Date/Time: Sun, 09 Feb 2025 06:22:42 +0000
Major Gaps in Historical Intraday Data & mismatch in Cumulative Volume Delta Bars
View Count: 561
[2020-08-13 18:08:34] |
User283563 - Posts: 1 |
I have a trial memebership. The Euro futures is a continuous contract with volume based rollover back adjusted. I'm getting major gaps as shown in the attached image. I also changed the rollover options but I'm getting the same result. Also cumulative delta bars are also not making any sense, I have selected reset at start at trading day = no. Many other futures continuous contracts are showing similar issues. Please help. |
[2020-08-13 18:45:40] |
This is the result of historical data download failures. You need to follow these instructions but you may still run into a problem if your Internet connectivity is not good: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Regarding Cumulative Delta Bars, make sure you fully understand that study: Cumulative Delta Bars - Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
