Date/Time: Sun, 09 Feb 2025 05:54:28 +0000
Study Issue
View Count: 644
[2020-08-13 17:54:08]
taipeicity - Posts: 52
Hello:
it happens all the time,
when I try to change some charts from (example) 15 minutes to 60 minutes chart
I am receiving the below error:
""You have performed an operation which cannot be completed because this chart is being referenced by studies in another charts in the chartbook. Do you want to clear those references?"
after press "YES", THE CHART CHchanged to 60 minutes chart briefly and quckly go back to 15 minutes chart again.
what should I do? PLEASE HELP
[2020-08-13 18:47:15]
In general, refer to:
Unable to Change the Bar Time Period for Charts
You will need to manually remove the reference between charts.
Date Time Of Last Edit: 2020-08-13 18:47:33
