Date/Time: Sun, 09 Feb 2025 23:42:56 +0000
Price Ladder - Bid & Sell Size Column
View Count: 730
[2020-08-13 17:35:50] |
User343319 - Posts: 5 |
Hi, For the Bid Size and Ask Size columns, there will not be more than one size/quantity row for the Bid and Ask sides, unless market depth data is provided for the symbol from the particular Data or Trading service being used. When using the symbols from the Sierra Chart Real-time and Historical Forex/CFD Data Service, there is only one level of market depth data with quantities of 1. Can this be changed so that the bid & sell size column has actual sizes ? |
[2020-08-18 12:32:21] |
You need to use the LMAX trading service for market depth data for cash Forex. Refer to: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-18 12:32:56
