Date/Time: Sun, 09 Feb 2025 23:57:21 +0000
Automatic trail
View Count: 813
[2020-08-13 16:24:50] |
User531621 - Posts: 103 |
Hi folks, can you please send a link or links to show me how to set up an automatic trail... as an example: i would like my position, if a long, to move 1 point automatically, when the price goes up 2 points... Thank you |
[2020-08-17 17:42:55] |
Havent heard back on my question as yet. please advise: Hi folks, can you please send a link or links to show me how to set up an automatic trail... as an example: i would like my position, if a long, to move 1 point automatically, when the price goes up 2 points... Thank you |
[2020-08-17 19:20:58] |
Hammerhead - Posts: 14 |
Hi, Order Types: Step Trailing Stop Look at "Step Trailing Stop". Regards, |
[2020-08-17 19:24:14] |
Yes look at this order type: Order Types: Step Trailing Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-17 19:24:23
