Date/Time: Sun, 09 Feb 2025 05:57:26 +0000
DOME Daily P&L Error
View Count: 546
[2020-08-13 12:29:54] |
Peter Heinrichs - Posts: 1 |
The daily p&l shows wrong amounts after trades are complete. I've set it to show points, currency, ticks etc. makes no difference, after a trade is complete it shows the wrong amount won or lost. A few times I've been plus hundreds and it shows negative hundreds. Thanks, Pete |
[2020-08-13 17:43:26] |
Refer to the information here for things to look at: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
