Date/Time: Sun, 09 Feb 2025 05:51:28 +0000
Sub Instance (New Install)
View Count: 517
[2020-08-13 11:57:29] |
User991052 - Posts: 33 |
Hi Support, Copied the Sierra.cfg file into a " Sub Instance " during file transfer. Q. Will this affect how the Sub Instance is viewed OR performs? Sub Instances has been set-up to manage multiple Trading DOM's ONLY. Q. Is it best to run the DOM ONLY set-up on a NEW Install? Regards, |
[2020-08-13 17:49:07] |
Q1. This will not affect the Sub-Instance at all. It just allows you to have the same global configuration as the main instance but this needs to be done when the sub instance is not running. Q2. This has no relevancy at all to whether the installation is new or not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
