Date/Time: Sun, 27 Sep 2026 02:19:54 +0000
Replay dialog speed drop down box becomes empty and remains so
View Count: 818
| [2020-08-13 05:05:30] |
| User186149 - Posts: 3 |
I noticed that if/when the replay dialog boxed is closed - once replay starts, then on subsequent openings of the replay dialog box, the speed drop down box is empty and remains so regardless of closing chartbooks, changing charts, starting/stopping/pausing replay, or changing settings (at least for me). Only by closing the Sierra Charts application and re-opening it, will the speed drop down box be populated with speed options again. My Sierra Charts version is 2138 but I noticed this behavior several versions ago. The behavior is repeatable (for me) regardless of charts, settings, markets, studies, etc. I would be interested if anyone else can confirm this behavior. 1. Select simulated trading. 2. Pull up a market (e.g. YM). 3. Open replay dialog. 4. Select accurate back testing 5. Select a start date of a week ago. 6. Start replay. 7. Select yes to erase past trading data. 8. Select play to start replay. 9. Confirm that replay is replaying the market. 10. Close the replay dialog box 11. Confirm that replay is still occurring. 12. Open replay dialog. From this point on I cannot get a populated speed drop down box for any chart let alone the one I was replaying. Not until I restart the Sierra Charts application. |
| [2020-08-13 05:38:40] |
Are you using Linux?
