Date/Time: Mon, 16 Sep 2024 19:05:35 +0000
Date/time anchors always grayed out in the tool properties
View Count: 1177
[2014-02-02 12:47:51] |
User62923 - Posts: 27 |
Why so? It would be very convenient to be able to adjust the date/time parameter in the tool properties. If a tool is a long one (like a trendline on 1 min chart), changing it by dragging it is not that easy. Gann Grid and price (value) range rectangles are other examples of when it would be a good option to have.
Date Time Of Last Edit: 2014-02-02 12:49:27
[2014-02-03 21:02:02] |
We will see about this.
