Date/Time: Tue, 04 Nov 2025 18:18:08 +0000
Sharing position data between 2 instances of Sierra Chart
View Count: 2533
[2013-04-17 09:41:46]
AB604E - Posts: 32
Is there any way to share Position Data and Open P/L between 2 instances of Sierra Chart using Spreadsheet for Trading?
[2013-04-17 13:30:13]
Sawtooth - Posts: 4285
You can reference other spreadsheets. Take a look at this:
http://www.sierrachart.com/index.php?l=doc/doc_Worksheets.html#CellandRangeReferencesandExternalReferences
[2013-04-17 14:33:05]
AB604E - Posts: 32
I did try "References to Other Spreadsheets Windows" but it is only work with two Spreadsheets that were open by the same copy of SierraChart (Same Data folder)
I can't reference to/ from other spreadsheet that is not in the same data folder.
[2013-04-17 14:47:55]
Yes, you are correct. I was mistaken. It only works within the same folder.
You used to be able to share data folders between instances, but that is no longer supported.
http://www.sierrachart.com/supportboard/showthread.php?t=42296&highlight=share+data+folder
