Date/Time: Sun, 09 Feb 2025 06:23:12 +0000
Stocks Tick Data
View Count: 525
[2020-08-12 22:09:02] |
User798786 - Posts: 4 |
Hi, I am using Sierra Chart with IQFEED for Stock Data. I would like to know how I can setup Sierra Chart to work with more than 5 days of Tick Data, for Stocks. I asked IQFeed, and they informed me that my data subscription has 180 days of Tick Data for Stocks. |
[2020-08-13 18:16:29] |
This is all explained here: DTN IQ Feed Data Service: Tick Data Limitation during Primary Session Hours And refer to this particular setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-13 18:17:47
