Date/Time: Sun, 09 Feb 2025 05:51:06 +0000
Is there a problem with your server?
View Count: 584
[2020-08-12 18:44:38] |
User378741 - Posts: 29 |
[2020-08-12 19:04:38] |
We do not know what you are referring to. This is not the right question to ask. What is the issue you are having. And no there are no problems with Sierra Chart servers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-12 19:07:48] |
User316362 - Posts: 210 |
I believe TransActWS users are all having issues again
[2020-08-12 19:08:55] |
the servers /data/connections are all working and fine. Of course I di not use TransAct.
[2020-08-12 19:15:01] |
Sorry, I am indeed a user of TransActWS. Just now, sc has been unable to connect to the server. I also purchased your own data source. If you use sc all servers, you can connect to the data. Then it should be the problem of TransActWS.
[2020-08-12 19:15:49] |
it is a TransAct issue. I heard they just got it going again.
[2020-08-12 19:42:29] |
Yes, my side is back to normal. Thank you very much for your reply. Have a nice day.
