Date/Time: Sun, 09 Feb 2025 05:46:18 +0000
Rectangle Study Hidden Behind Study Subgraphs Reference Study
View Count: 984
[2020-08-12 17:52:35]
User326940 - Posts: 23
My rectangle study gets hidden behind a Study Subgraphs Reference Study (which is shading the area between 2 VWAPs).
I would like the rectangle to draw over this shaded area.
What should I do?
Here is a photo:
https://gyazo.com/eb4175efc82abb346b17ce48042872e6
Date Time Of Last Edit: 2020-08-12 21:17:32
[2020-08-13 07:46:24]
Ackin - Posts: 1865
My rectangle study
Try:
adjusting the study display order on the chart
Chart Studies: Chart Studies Window
and
Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Advanced Settings menu)
Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Advanced Settings menu)
Draw Advanced Custom Study Drawings Above Other Drawings (Chart >> Chart Settings >> Advanced Settings menu)
[2020-08-13 12:56:58]
Thank you Ackin!
Unchecking "Draw Highlight Drawings Underneath Main Graph and Studies" did the trick!
