Date/Time: Sun, 09 Feb 2025 05:42:45 +0000
Composite Volume profile on TPO Chart
View Count: 2068
[2020-08-12 17:17:46] |
Sudhirc - Posts: 54 |
Hello, I'm trying to plot TPO profile along with Composite Volume Profile for all bars in chart option(33) Selected studies: 1. TPO Profile chart 2. Volume by price to get composite volume profile. in Volume by price study for input Volume Graph Period Type (In:33) I selected: All Bars in Chart option to get composite profile, but when apply it is automatically get changed to Based on TPO Chart and i'm getting volume profile along side TPO profile. How can i get Composite volume profile? Thank you. http://www.sierrachart.com/image.php?Image=1597252594383.png |
[2020-08-12 18:37:20] |
You need to use this Input: Volume By Price Study: Set as Independent Volume Profile for TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-12 20:15:47] |
Thank you so much. Worked out great. One more question, can it be aligned to the left? under input, RightAlign Volume Bars (In:45)--its not letting me to plug in "NO" to have it aligned to the left of the chart. |
[2020-08-12 23:08:41] |
No, you cannot change the alignment to the right when you use the option for it to be an Independent profile from the TPO. Refer to the information here: Volume By Price Study: Set as Independent Volume Profile for TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
