Date/Time: Sun, 09 Feb 2025 06:23:44 +0000
access every single executed order
View Count: 516
[2020-08-12 16:23:32] |
IGOR A - Posts: 2 |
I am trying to retrieve every single executed order programmatically, is there a function I can work with?
[2020-08-12 18:33:07] |
Yes, refer to: Automated Trading From an Advanced Custom Study: sc.GetOrderFillEntry() You should also use this particular service so you have full access to the order fill history: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
