Date/Time: Sun, 09 Feb 2025 05:52:56 +0000
Configuration File account checksum error
View Count: 706
[2020-08-12 15:49:02]
Ben A - Posts: 123
I keep receiving the error; "Configuration File account checksum error" and also the error; "configuration file size of 26 bites is not the 437357 expected bytes to write. The configuration file may be corrupt".
I came to my workstation today and everything has been reset and chart-books wiped.
I restored an earlier version of chart-books and settings, however when I restarted my machine, the same thing occurred.
Please can you advise on the potential issue and whether there is a resolve for this?
Thank you,
Ben
Date Time Of Last Edit: 2020-08-12 17:21:17
[2020-08-12 17:37:25]
Did you try restoring a backup of the configuration file itself? Instructions:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
[2020-08-12 17:43:01]
Ben A - Posts: 123
I did do that, yes
Should I try an earlier one perhaps?
Ben
[2020-08-12 18:26:14]
Use an earlier one that is not giving a checksum error.
[2020-08-12 18:30:00]
Ben A - Posts: 123
Thank you,
After replacing that file, I can now login, however now I have a problem that historical data downloads but new candles/lines are not printed and all charts are static despite appearing to be connected.
I have restarted PC and Sierra to no avail.
Is there also any way that I can also restore my toolbar configuration as this has reverted to default.
Thanks,
Date Time Of Last Edit: 2020-08-12 19:50:09
[2020-08-12 20:44:01]
Ben A - Posts: 123
Here is my Log,
I have Denali and IB:
Thank you for your advice
Reading Internal Order ID file. | 2020-08-12 20:35:00.911
Reading Trade Orders file. | 2020-08-12 20:35:01.326
Reading Trade Positions file. | 2020-08-12 20:35:01.326
Reading Account Balance file. | 2020-08-12 20:35:01.327
UDPListener (1288). Port 22904 | Listening on UDP port 22904. | 2020-08-12 20:35:01.374
Software version: 2128 64-bit | 2020-08-12 20:35:01.374
Primary Thread ID: 8856 | 2020-08-12 20:35:01.374
Usage end date: 2020-08-31 | 2020-08-12 20:35:01.374
Enabled for: Advanced Features 2. | 2020-08-12 20:35:01.374
Enabled for: Sierra Chart Historical Data Service. | 2020-08-12 20:35:01.374
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-08-12 20:35:01.374
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-08-12 20:35:01.374
Enabled for exchange2: CME (Trading Account Required) | 2020-08-12 20:35:01.374
Enabled for exchange2: CBOT (Trading Account Required) | 2020-08-12 20:35:01.374
Enabled for exchange2: COMEX (Trading Account Required) | 2020-08-12 20:35:01.374
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-08-12 20:35:01.374
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-08-12 20:35:01.374
Current selected Data/Trading service: SC Data - All Services | 2020-08-12 20:35:01.374
Custom symbol settings values: enabled | 2020-08-12 20:35:01.374
Chart Update Interval: 500 | 2020-08-12 20:35:01.374
Intraday Data Storage Time Unit: 0 | 2020-08-12 20:35:01.374
Time Zone: +00:00:00 (UTC+00) | 2020-08-12 20:35:01.374
2020-08-12 21:35:01 Local computer time | 2020-08-12 20:35:01.374
2020-08-12 20:35:01 Local computer time in UTC | 2020-08-12 20:35:01.374
2020-08-12 20:35:01 Local computer time in SC Time Zone | 2020-08-12 20:35:01.374
2020-08-12 20:35:00 Server time in UTC | 2020-08-12 20:35:01.374
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-08-12 20:35:01.374
Program path: C:\SierraChart\ | 2020-08-12 20:35:01.374
Data Files path: C:\SierraChart\Data\ | 2020-08-12 20:35:01.374
OS Version Number: 10.0 | 2020-08-12 20:35:01.375
Locale Setting: C | 2020-08-12 20:35:01.375
Allowed protected custom studies: SST_FreeBundle, zyp_download_free | 2020-08-12 20:35:01.375
[2020-08-12 21:21:50]
The problem is most likely what is explained here:
Data/Trading Service Connection and Symbol Issues: 1.3. Symbols
You do not have Sierra Chart set to use Interactive Brokers. That is the problem.
Date Time Of Last Edit: 2020-08-12 21:22:18
[2020-08-12 21:31:43]
Ben A - Posts: 123
Ah, OK, thanks, will have to work out how to reconnect again.
Can you advise how I return my toolbar please? And also, is there a way I can avoid such a problem again?
Thanks,
[2020-08-12 21:46:38]
Here are the interactive brokers set up instructions:
Interactive Brokers Trading Service: Setup Instructions
This is done by restoring a global configuration file, from a date that has the configuration that you want, assuming that file is usable.
Clearly something went wrong with your system causing the configuration file to become corrupted which caused the issue. That is why there are backup configuration files.
