Date/Time: Sun, 09 Feb 2025 06:13:54 +0000
Sub Accounts
View Count: 656
[2020-08-12 15:00:15] |
User991052 - Posts: 33 |
Hi Support, Does Sierra offer the ability to set-up " Sub Accounts " essentially allowing user to trade MULTIPLE INSTRUMENTS (SAME INSTRUMENT) from the ONE Account? i.e Sim1 / Sim1_a Regards, |
[2020-08-12 18:57:20] |
Yes, you can do this. It is really dependent on your broker setting up your accounts, and not Sierra Chart. If you have multiple accounts that can be accessed through the same login, then they will show up in Sierra Chart and then you can use the Order Allocation to Trade Accounts feature. Refer to the information here: Order Allocation to Trade Accounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
