Date/Time: Sun, 09 Feb 2025 05:41:56 +0000
Order Routing Service With Data - funded accounts
View Count: 636
[2020-08-12 07:48:21] |
User257019 - Posts: 25 |
Hello team, and apologies for my lack of knowledge on this. I use funded accounts like uprofit, earn2trade, topsteptrader... I would like to trade in one in the graph and replicate into the others (entering orders, moving stop, target...). All of them are using Rithmic and I know the suggested way is using the order routing with data (TT), however I don't know if those would support it as you need to know the clearing firm to create the request to you. Have you tried this before with funded accounts? if so, what's your experience? do you know if it's possible to do what I want? THANKS. |
[2020-08-13 18:14:04] |
It definitely is not possible to what you want with Rithmic and Sierra Chart. As you stated, it could be done if you are using the Sierra Chart Order Routing Service, but that order routing service is not supported by the firms that you mention. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-13 18:14:52
[2020-08-13 18:27:34] |
:( If I was willing to use Sierra Chart older versions for those firms (that use Rithmic) because I like your platform even it wouldn’t be supported; how could I replicate what I do in one to the rest? Could I have different sub-instances or completely different instances and copy the orders through DTC programming it? (Or if you have any other ideas). Thanks a lot. |
[2020-08-13 18:48:26] |
This is beyond the scope of our support.
