Date/Time: Sun, 09 Feb 2025 03:45:02 +0000
Trial ending - will be signing up with Stage 5 Tradi - questions
View Count: 737
[2020-08-12 02:55:29] |
PhiX - Posts: 36 |
My SC trial expires tonight. My trial account with Sierra Chart was created with the login WKoesters. I will be creating a Trust account with Stage 5 under the name "Koe**". I want Service Package 5 with Sierra Chart Futures Order Routing Service with Denali data and order routing by TT. Can I use the same trial software I have currently or do I need to download again? I modified a number of settings I would like to keep. Do I keep the same SC account or create another under the name Koe**? My email is **. Thank you.
Date Time Of Last Edit: 2020-08-12 08:02:12
[2020-08-12 08:01:48] |
Can I use the same trial software I have currently Yes. Follow the instructions here:Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
