Date/Time: Sun, 09 Feb 2025 06:21:18 +0000
Adding space in between PnF bars
View Count: 735
[2020-08-11 21:19:38] |
User207252 - Posts: 14 |
Looking to add space in between point & figure bars? The added studies overlap to previous bars and makes it difficult to read Date Time Of Last Edit: 2020-08-14 03:46:55
Private File |
[2020-08-14 10:27:33] |
Refer to: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
