Date/Time: Thu, 24 Sep 2026 01:32:51 +0000
Price Multiplier doesn't work on Add Additional Symbol study
View Count: 1534
| [2020-08-11 19:10:40] |
| skelcap - Posts: 139 |
On the Add Additional Symbol study, the Price Multiplier field doesn't have any effect.
| [2020-08-11 20:05:12] |
There is no problem with that input. We have tested it and there is no reason why there would be an issue. Is this a Historical Daily Chart or Intraday chart?
| [2020-08-12 18:27:04] |
The problem appears to be with the symbol I'm using - $DNX. With that symbol the Price Multiplier doesn't have any effect on a Daily chart and on an Intraday chart the symbol won't show at all (says 0 value at every point). If I replace it with a different symbol like $INX then on the Intraday Chart the symbol shows and the Price Multiplier works, but on the Daily Chart the Price Multiplier still doesn't work (I tried ES-202009-GLOBEX as well to see if the problem was because it's a cash index, but the multiplier still didn't work nor for an FX symbol like AUDUSD).
| [2020-08-12 21:48:26] |
We cannot provide further help.
| [2020-08-12 22:47:04] |
Can I at least share the chart with you to see if you have the same problem?
| [2020-08-13 17:33:31] |
Normally I'm impressed by your level of support but on this issue I don't understand why you won't look into it further. I've been playing around with the Additional Symbol -> Price Multiplier with different symbols on different charts and I keep running into the same problem. It seems strange to imagine that it's something wrong with my setup.
| [2020-10-26 13:41:00] |
Sorry but this issue is really bugging me. Please could you have a look at the attached chartbook and tell me if you see the same thing: the -1 Price Multiplier for the Add Additional Symbol study works on the intraday chart but not on the daily chart. If so, please can you fix this issue. I've provided a screenshot so you can see what I'm seeing. I'm using Sierra Chart Exchange Data Feed and Interactive Brokers trade service. I use this all the time to invert symbols and overlay them on other charts. The only other way round I can see is to use the Overlay study but that requires opening a new chart for every symbol you want to overlay, which is cumbersome. I imagine other users want to do the same thing as well. Thanks. |
Private File Private File |
| [2020-10-26 18:41:16] |
We did discover one problem under certain conditions related to this and it was corrected. Update the latest version and see if you still notice the problem. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-27 00:00:44] |
That works now thanks.
