Date/Time: Sun, 09 Feb 2025 04:03:20 +0000
Wrong Data on chart fills
View Count: 522
[2020-08-11 16:48:00] |
Chippstrader - Posts: 30 |
I see an issue with the chart fills showing wrong on my chart. Any advice.
Chart Fills Mess up.png / V - Attached On 2020-08-11 16:47:39 UTC - Size: 93.93 KB - 193 views |
[2020-08-11 18:42:12] |
What is the problem? Refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-11 18:52:58] |
Thank you.
