Date/Time: Sun, 09 Feb 2025 03:43:59 +0000
Close Event Error
View Count: 535
[2020-08-11 16:37:35] |
User249370 - Posts: 1 |
Close Event Error - The data provided by Brocker was disconected. Internet connection have not failed. I just sent the Message Log directly from Sierra Chart. Thanks. |
[2020-08-11 17:21:33] |
You definitely did have a problem with your Internet connection. That is abundantly clear: GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-08-11 12:16:10.813
GAIN Capital FIX Trading socket (1) | Using previously cached IP address because unable to resolve domain name | 2020-08-11 12:16:10.813 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-08-11 12:16:10.813 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-08-11 12:16:10.814 GAIN Capital FIX Trading socket (1) | Connect event error. Windows error code 10065: Se ha intentado una operacin de socket en un host no accesible. | 2020-08-11 12:16:10.814 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-11 17:21:51
