Date/Time: Sun, 09 Feb 2025 03:42:19 +0000
GLOBAL PROFIT/LOSS MANAGEMENT update commissions
View Count: 647
[2020-08-11 15:28:15] |
paucansam - Posts: 1 |
I would like to know if it is possible to configure the GLOBAL PROFIT/LOSS as follows: Currently I have set a target of $ 200, but if the commission per trade is $ 5 and I make 4 trades before reaching my target, it is reduced to $ 180 ($ 200-$ 20 (commissions)) Is it possible for the target to be updated based on the commissions generated? In the previous example the target should have increased to $ 220 so that the net profit would have been $ 200 as I want it to be thank you! |
[2020-08-11 18:45:05] |
If you want to include commissions in the calculation of profit/loss values, then for the charts being used in the calculation which you can tell from this tab: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab you will then want to enable this option: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-11 18:46:24
