Date/Time: Sun, 09 Feb 2025 04:10:55 +0000
Delayed response between mouse command and chart
View Count: 692
[2020-08-11 12:07:48]
User537081 - Posts: 7
With any command selected there is a delayed response - a lag of between 1/2 a second and 2 seconds. A sticky mouse. The mouse works perfectly with any other function on the computer but only with sierra charts there is a delay. Computer is new with clean install. Intel core i7-10700K CPU, 64 bit OS. So for simple example: click crosshair tool then wait for one second before it becomes useable.
[2020-08-11 19:16:43]
This is a performance issue, refer to this help topic:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Are there a lot of chart drawings on the chart? You can check in Chart >> Manage Chart Drawings window. A lot would be hundreds.
Date Time Of Last Edit: 2020-08-11 19:16:50
[2020-08-12 09:13:25]
Many thanks for your reply. Yes, I aggree the problem would seem syymptomatic of performance. However, I am using a brand new trading computer which I have only just fired up with sierra chart. As such I am only running six charts to get started. I attach the computer spec which ought to more than satisfy the ability to run sierra software. There are minimal apps working in the background and minimal apps installed - the main , higher impact apps are microsoft office 365, edge and firefox. Security is Kaspersky total security. There ought to be more than adequate performance cpability.
Private File
