Date/Time: Sun, 09 Feb 2025 04:26:35 +0000
[Programming Help] - Drawing Inconsistent, Serious Concern
View Count: 546
[2020-08-11 08:17:29] |
RolandC - Posts: 54 |
Same chart, Same symbol. If I change "Days to Load" under Chart Settings, the green line changes position?
90 days download.PNG / V - Attached On 2020-08-11 08:16:47 UTC - Size: 78.62 KB - 232 views 30 days download.PNG / V - Attached On 2020-08-11 08:16:55 UTC - Size: 83.42 KB - 213 views |
[2020-08-11 08:25:20] |
Refer to this page: Lines/Rays or Other Chart Drawings Move After Drawing Them We will not provide any further response here. You need to read through that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-11 08:25:30
