Date/Time: Sat, 28 Nov 2026 11:21:50 +0000
[User Discussion] - CSV to Spreadsheet
View Count: 1375
[2020-08-10 23:26:08]
User253985 - Posts: 24
Hi
Is it possible to upload live data from a .csv file to the spreadsheets?
Is there a study which will do this?
Is it possible to upload a live .csv file which has volume data in it and use that data as volume for an instrument?
If so how can this be done?
[2020-08-11 12:07:03]
Sawtooth - Posts: 4362
No, and no.
You can manually import static CSV data:
Exporting and Importing Intraday Data Files: Import and Load
Text/CSV Data Format
Why not use the Spreadsheet Study study to live calculate your custom volume?
