Date/Time: Sun, 09 Feb 2025 04:07:42 +0000
Stochastic Crossover System bug: Up/Down arrows not reliably displayed on range chart.
View Count: 924
[2020-08-10 17:48:34] |
User684222 - Posts: 2 |
The Stochastic Crossover system study is not reliable on a range chart. It does not display an up or down arrow every time the slow and fast lines cross, even when there is a pronounced difference in the slope of the two lines. There is no problem on time based charts. See attached range chart and note the green rectangles showing the crossovers where there are no arrows displayed on the main panel. Both studies are using 10,3,3 for the settings. Date Time Of Last Edit: 2020-08-10 18:31:40
[2020-08-10 20:20:02] |
Provide that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-10 21:02:45] |
Resolved: If the setting "use buy/sell lines" = NO, then all up/down arrows appear on the price panel. Please close. Date Time Of Last Edit: 2020-08-10 21:05:53
