Date/Time: Sun, 09 Feb 2025 03:59:53 +0000
REALTIME DATA - CME BUNDLE
View Count: 1118
[2020-08-10 16:49:04] |
User991052 - Posts: 33 |
Hi support, Seeking clarity around DATA/ROUTING options available w/ Sierra. Q. Is the BUNDLED SIERRA CHART EXCHANGE DATA FEED still available to users? Information found on your website points to DENALI DATA FEED being the ONLY recommended data feed for CME Group of Exchanges. Q. If so, does SIERRA CHART ORDER ROUTING SERVICE allow connection (clearing) through Advantage Futures? Regards, |
[2020-08-10 17:45:08] |
Q1. The Sierra Chart Exchange Data Feed is still available, but if you need data from the CME Group, then that comes from the Denali Exchange Data Feed. Refer to the information here for what is available in each feed: Real-Time Exchange Data Feeds Available From Sierra Chart Q2. Yes, Advantage Futures offers the Sierra Chart Order Routing option. Refer to the Setup Instructions for the SC Order Routing here: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-11 13:59:18] |
Hi Support, Thank you for the reply. Is ADVANTAGE FUTURES a " supported trading service " for the purposes of receiving Non Professional CME Data? Regards, |
[2020-08-11 19:02:10] |
If you are using Sierra Chart Order Routing Service, then that works as your trading account for the CME to see you as a Non-Professional assuming you are a nonprofessional and not a professional.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-11 19:02:18
