Date/Time: Sun, 09 Feb 2025 03:54:31 +0000
macd & rsi
View Count: 870
[2020-08-10 16:32:42] |
User426295 - Posts: 3 |
hallo i would like to connect the rsi with the macd, in a way when the rsi goes into a zone of excess (sale or purchase) the macd is colored
[2020-08-10 19:22:54] |
You need to use the Color Bar Based on Alert Condition study. You will find the information here: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
