Date/Time: Sun, 09 Feb 2025 04:20:53 +0000
[User Discussion] - Extra Option In Time Sales Settings and New Version of Large Trade Volume Study
View Count: 1006
[2020-08-08 17:38:28] |
User336770 - Posts: 30 |
@Sierra Engineering: Hello there, is it possible for you to add an extra option in Time Sales settings in a next release? Would like to see this option: Combine Records into Exchange Reported Original Summary Trade + Same Type and Time. So it would not only reconstruct the orders, but also consolidate these orders based on type + time. Combine Records into Exchange Reported Original Summary Trade + Same Type, Price and Time. Combine Same Type + Same Time + Same Price Can you make a new version of the Large Trade study, but one that uses the same settings of Time and Sales? Very simple inputs: Combine Records (same options from time sales) Input Filter Min (if set to 30 for example, will only combine orders above 30 lot) Output Filter Min (if set to 500, will only show on chart consolidated orders above 500) Thank you Date Time Of Last Edit: 2020-08-08 20:51:56
[2020-08-08 19:02:45] |
Just complementing my post above so I don´t need to open a new thread, wanted to know if it is possible to adjust the space between the values of time and sales horizontally so they are closer to each other.
[2020-08-11 11:14:07] |
@Sierra Chart Engineering How come this is "user discussion"? I specifically requested that an option be added to time and sales window. Requested to Sierra Chart Engineering, not users. The options are already there, can´t you guys simply add an extra option "Combine records with same type, time and price" ??? Why is this not even there already? Regards |
[2020-08-11 11:25:47] |
This is far too involved for us to be adding and it is not something we will be doing.
