Date/Time: Sun, 09 Feb 2025 02:43:46 +0000
Programming request for tool enhancement and replay issue.
View Count: 751
[2020-08-08 13:35:05]
User92573 - Posts: 541
Dear Support
I appreciate you are very busy however I would be happy contribute to the programming costs for both enhancing and correcting the following tools.
1) Price retracement, expansion and projection tool enhancement such that 'just as in the line-tool' the end can be dragged to a desired point. At this time these tools are limited to either fixed locations or the multiplier.
2) Programming adjustments to correct the Replay issue that results in unexpected outcomes on all charts that are numbered above the #chart on which Replay was selected.
Example 1:
Select >> chart#1 of 5
Select >> Replay >> All charts in chartbook >> Accurate back testing mode.
Pause >> Replay >> Select Jump method: To Next Bar >> Back 1 >> Forwards 1. (All charts > #1 show just a single bar at left side).
Example 2:
Select >> chart#2 of 5
Pause >> Replay >> Select Jump method: To Next Bar >> Back 1 >> Forwards 1. (All charts > #2 show just a single bar at left side).
Hope this helps. I have posted the replay issue before but probably not in enough detail.
Please would you provide a quote for the enhancing of the ratio tools and correcting the replay issue.
Great Platform!
Many thanks
