Date/Time: Sun, 09 Feb 2025 02:59:07 +0000
[User Discussion] - P&L only goes back a week?
View Count: 543
[2020-08-07 20:19:49] |
User972917 - Posts: 4 |
Good day!, I'm trying to look at my monthly P&L and yearly for that matter but I am only seeing the last week, I understand how to change the from and to date properly. Any ideas? Thank you |
[2020-08-07 21:09:16] |
You really want to switch to the Sierra Chart order routing service which will provide long-term order fill history: Sierra Chart / Trading Technologies Futures Order Routing Service Otherwise, with CQG you only have access to one day of order fills. But Sierra Chart does accumulate them but you would need to keep Sierra Chart running all the time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-07 21:09:22
