Date/Time: Sun, 09 Feb 2025 04:09:43 +0000
Denali Data
View Count: 563
[2020-08-07 19:17:11] |
Sujit Mapadath - Posts: 2 |
TopStep uses Tradovate and CQG. My userid for TopStepTrader does not work with Sierra. As for TD Ameritrade, i do not see any options for connecting to TDA. Thanks |
[2020-08-10 13:23:48] |
John - SC Support - Posts: 37842 |
We do not offer a connection to TD Ameritrade. As to CQG, this is supported, so you should not have any issue connecting using your CQG identification. Follow through the Setup Instructions here to connect to CQG: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
