Date/Time: Sun, 09 Feb 2025 03:21:37 +0000
Use MiniReal Price Feed
View Count: 563
[2020-08-07 17:38:52] |
User869657 - Posts: 31 |
Hello, When selecting in "Data/Trade Service Settings" the service "FXCM Live Trading", there is a parameter "Use MiniReal Price Feed". I've looked in the documentation but couldn't find anything ; I have only found mention of it in this support board post : Spread with FXCM Could you please let me know what it corresponds to ? Thanks |
[2020-08-08 02:04:33] |
FXCM has two different data feeds. When that option is set to true, then that particular data feed is used. It affects the spread between the bid and the ask.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-08 02:04:39
