Date/Time: Sun, 09 Feb 2025 03:13:30 +0000
Spreadsheet question
View Count: 551
[2020-08-07 17:38:20]
zippyzip - Posts: 293
hey guys is there a way to add a new study to the chart with out it moving the spreadsheet lettering for example if id.sg1 is at AA and i reference AA if i add a study to chart then AA gets moved to a new lettering .
please let me know or should i not reffence the lettering in the spread sheet and only use the study ID , thanks
[2020-08-07 19:37:11]
You are best off to use the direct study reference method so you do not need to worry about it. Refer to the information here:
Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study
