Date/Time: Sun, 09 Feb 2025 03:59:38 +0000
installer not launching
View Count: 607
[2020-08-07 16:34:12] |
mazzy /| blast - Posts: 54 |
Windows Server 2016 x64. I had no problem in the past. Today, can’t launch the installer at all. Here’s a video *deleted* Date Time Of Last Edit: 2020-08-07 17:33:41
[2020-08-07 17:14:54] |
Use the Zip installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-07 20:05:18] |
Thanks. Unzipped it in C:\SierraChart Same problem : impossible to launch SierraChart.exe This is curious cause the operating system of my VPS is clean / freshly installed and dedicated to trading only - haven’t installed crap apps. Supposedly, my Windows isn’t deteriorated |
[2020-08-07 21:10:22] |
Is there any error message displayed? Did you check the Windows Event viewer to see what the problem is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-07 21:10:31
[2020-08-09 11:19:50] |
Didn’t know where to look at in the event viewer. I resintalled Windows Server 2016 on the VPS completely. The same problem continued. Then I created a new Windows user with admin powers and from there, now it works. Date Time Of Last Edit: 2020-08-09 11:20:13
