Date/Time: Mon, 25 Nov 2024 10:28:22 +0000
Horizontal Scrolling
View Count: 2917
[2014-02-01 16:46:14]
leftbrain - Posts: 7
Is there any way to scroll a chart window horizontally without dynamically changing the scale or positioning of the vertical axis? I would like to be able to scroll left and right without any effect on the vertical presentation.
[2014-02-02 04:50:03]
Two ways come to mind.
One way would be to use Constant Range scale without Auto Centering.
And uncheck this option in the Scale window: Constant Range Scale: Re-Center on Chart Scroll.
The other way would be a User Defined scale.
For more information, refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ScaleWindow
[2014-02-02 05:46:24]
That's perfect. Now, how can I make this the default setting for all new charts?
[2014-02-02 06:00:09]
See 20.2 here:
https://www.sierrachart.com/index.php?l=doc/helpdetails20.html
[2014-02-02 06:13:37]
That makes sense. I was looking for a global way to do these things but the better method is to duplicate my favorite chart setting(s) as needed. Thanks.
