Date/Time: Sun, 09 Feb 2025 03:13:57 +0000
Scaling different indicators in a pane
View Count: 783
[2020-08-07 16:02:26] |
User491464 - Posts: 21 |
Hello, I have 3 different indicators in one pane and they are stacked above and below each other, I want them on top of each other despite the different scales. Is this possible? Thank you |
[2020-08-08 02:32:29] |
The only way to get close to what you want is to set the indicators to have Independent scaling. This will put them into the same view in the region. But there is no way to specifically align them within the region if they are all using different scales. Refer to the information here regarding Independent scale: Chart Scale and Scale Adjusting: Independent (Scale Range) And refer to the information here for how to change the scale for a study: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
