Date/Time: Sun, 09 Feb 2025 03:14:02 +0000
unable to post orders
View Count: 543
[2020-08-07 13:45:00] |
User250840 - Posts: 37 |
unable post new orders using ver 2146/64 getting error of "expiration date of GTD order cannot be scheduled on a week end".was wrking fine earlier on ver 2144 and 2146. any suggestions ? rebooting did not help. dates appear ok, |
[2020-08-07 13:48:27] |
above occuring on live mode. on Sim mode all seems ok anything to do with expiration? using emin sept expiraion Date Time Of Last Edit: 2020-08-07 13:49:55
[2020-08-07 14:02:44] |
John - SC Support - Posts: 37842 |
What is your Time in Force set to for this order? It sounds like it it set to expire on the weekend, which it is telling you cannot be done. If you want it to expire at the end of the day, then set it for Day. Refer to the information here: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
