Date/Time: Sun, 09 Feb 2025 03:46:53 +0000
Stop All - Separate
View Count: 840
[2020-08-07 12:18:22] |
User969241 - Posts: 110 |
Was this function or solution ever added? separating out stop orders. |
[2020-08-08 02:45:22] |
Yes the command for it is in: Global Settings >> Customize Chart Trade Menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-08 07:04:21
[2020-08-08 11:04:25] |
Is it - Remove Link Between Stop Attached? Do I just right click on the combined stop all and click that? |
[2020-08-10 06:37:40] |
Refer to the documentation here: Order Types: Remove Link Between Stop Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
